Sean's RV 7 Project
Date:  4-18-2015
Number of Hours:  1.50
Brief Description:  Overhead Lights
Like so many builders have done, I decided to fabricatge and install a panel on the overhead brace in the baggage area. I decided to utilize two gooseneck LED lights. Each has tw o red and two white LEDs. My thought is this will serve the seating areas and baggage area, depending on where they are aimed.
Clamping panel.
Clamping panel.
Edge holes drilled.
Edge holes drilled.
Trial fit in plane.
Trial fit in plane.
