Sean's RV 7 Project
Date:  9-30-2014
Brief Description:  Making cut line for canopy
I took time to get the canopy positioned very close to its final spot, then began transferring the underlying cut line to the top of the plexi. I started by using blue painter's tape and then built that up using several layers of duct tape. This should make a light track for the cutting wheel and help me keep it straight. I checked and re-checked everything quite afew times to get it right. This cut just needs to be close,not perfect at this time.
Need to duplicate this line to plexi.
Painter's tape on both sides of line.
Duct tape makes the final guide.
