Sean's RV 7 Project
RV7
Canopy Frame Prep
Continued fitting the canopy frame. Filed off the welds that cause the skins to not sit flush. Continued duburring the rest of the frame. The outboard sides are not even close to where they should be. This will be an iterative process for sure.
The under belly of the forward canopy frame.
Initial fit is decent.
Sneak peek from the cabin side.
RV7 Home
315
Baffles
Baggage Area
Cabin
Canopy Frame
Center Console
Empennage Assembly
Exhaust
Grips
Hangar
Lights
Panel
Pitot Static
Seats
Smoke System
Upper Forward Fusela
Wiring
Workshop
