Brief Description: Mating Mid Section to Forward Section
Things are going together great. However did have a small problem with the fit between the mid section and the forward section. The rivet holes lined up pretty good at the bottom but, I was out about a full 3/8" at the top. Searched the forum for similar situation but couldn't find anything. Called Vans and go right throught to Scott. Seems this is a fairly common occurance and due to the rigidness of the components at this area it is a pretty good pull to get things together. Started clecloing at the bottom and pulled the parts together as I went up. Scott suggested to use a small punch about 2 holes up to assist in getting the parts together. That worked very good. Zipped up both sides with no real issues......
