Have been on vacation and not makin' much time untill today, got a lot of work done and feel really good about my progress. No problems at all untill the end of finishing the right side. I noticed my bend on HS-810 and HS-814-1 was to great. I thought I had it dead on 6 degrees as spec'd. Must have been more like 10 or 12. After I removed the skin and nose rib. I only removed the clecos right at the bend, then using the flush rivet set and heavy bucking bar, I gently tapped the forward side of the bend and it shallowed right up. I then replaced a skin to make sure I hadn't screwed up any of the alignment. Seems all is well! I did a quick assembly of the complete skeleton and it looks great!
