BOB'S WEB SITE
Date:  11-18-2017
Number of Hours:  5.00
Manual Reference:  11-2, 11-3
Brief Description:  Fit Elevators to Horitontal Stabilizer
Installed Rod End Bearings into both Elevators. Fit both elevators. Made adustments to ensure proper travel using a SmarLevel - was able to reach nearly 32 degress up Elevator and a little over 26 degrees down Elevator, and to ensure counter weight rib was parallel to Horizontal Stabilizer end rib. Trimmed drill-guide bushing to fit Elevator Horn bearing. Match-drilled Elevator Horn hinge point for both Elevators. Lastly, fabricated the drill-giude and drilled the Elevator pushrod bolt hole.
Happines is a parallel gap
Left Elevator ready to be drilled
Drilling left Elevator hing point
