Brief Description: Fit Elevators to Horitontal Stabilizer
Installed Rod End Bearings into both Elevators. Fit both elevators. Made adustments to ensure proper travel using a SmarLevel - was able to reach nearly 32 degress up Elevator and a little over 26 degrees down Elevator, and to ensure counter weight rib was parallel to Horizontal Stabilizer end rib. Trimmed drill-guide bushing to fit Elevator Horn bearing. Match-drilled Elevator Horn hinge point for both Elevators. Lastly, fabricated the drill-giude and drilled the Elevator pushrod bolt hole.
