Riveted the HS nose ribs to the HS skins. Tyler helped with the 8 rivets at the very tip of the nose ribs because I could not reach inside the skins with the bucking bar far enough and hold the rivet gun. Fitted the main spar and inspar rib assembly to the nose ribs.
