Gathered all the parts for the firewall and boot cowl. Pinned firewall to fuselage and started transfer drilling firewall to tabs. Pinned engine mount to firewall and drilled the two bottom holes through firewall and fuselage. Located and drilled holes for voltage regulator, battery box and starter solenoid. Transfer drilled tangs for rudder pedal springs #11 through firewall.
