Brief Description: Bottom Formers, VS Compression Rib
Fit, drill, ream ends of tubing and welded stubs. Spliced two formers together using solid 3/16 dowel rods and stainless APR40 rivets. Fabbed standoffs for bottom formers and safety wired 3 bottom formers to fuselage. Positioned Vertical Stabilizer compression rib, transfer drilled, deburred and riveted in place.
