Brief Description: Tank Mounting Bracket Installation
Riveted U-Brackets to outer tank support braces. Installed tanks, pushed forward, bolted wing tank brackets to tanks and center them in the bolt holes and on the tubes. Drilled brackets to tubes #40, then transfer drilled to #30. Remove brackets, deburr, reinstall and rivet. Rivet stems protruded from rivet heads so die grinder and scotchbrite wheel were used to remove the excess stem.
