Brief Description: Right Aileron Bellcrank Assembly
Gathered all the parts for the aileron bellcranks. Polished spindles for proper bearing fit. Pressed upper bellcrank arm onto spindles and transfer drilled to #30, disassemble, deburr and rivet arms to spindles. Assembled right bellcrank assembly and transfer drill bellcrank arm to spindle #11. Disassemble, deburr and reassemble then mount on right wing frame. Riveted rib reinforcement to #8 rib.
