RV
Date:  7-8-2008
Number of Hours:  1.00
Manual Reference:  6-6
Brief Description:  Worked on Rudder Skeleton
I fluted the tip rib and counterblance rib and then clecoed and match drilled the rudder spar and tip rib. I clecoed and match drilled the counterbalance skin to the ribs. Finally I clecoed the R-901R&L rudder skins to the skeleton along with the R-916 trailing edge in preparation for match drilling.
