RV
Date:  7-5-2008
Manual Reference:  6-5
Brief Description:  Deburred Rudder Stiffeners and Dimpled
I deburred all the match-drilled holes in both the rudder stiffeners and the rudder skins. I used a hand-squeezer to dimple the stiffeners and the C-frame tool to dimple the holes in the skins. After holding the spar up to the skins with the stiffeners clecoed on, I noticed I need to trim a little bit more off the front edge of the stiffeners so the spar will fit.
