RV
Date:  4-12-2008
Number of Hours:  5.00
Manual Reference:  6-2, 6-3
Brief Description:  HS Rib & Skin Work
Continuing with the skin and rib work from the previous day, I performed the required match drilling for the left HS skin/ribs, then assembled the right HS skeleton and fastened the skin. Each of the HS skins were attached one at a time in order to match drill the factory holes and to create the required skin-to-rib attachment holes that weren't already made. I then disassembled everything so that all holes can be deburred and dimpled as required, and the skins can be edge-finished and primed.
