Brief Description: F-705 Bulkhead Work and Priming
I used a bending break to finish fabricating the seat adjustment supports for the F-705 bulkhead. I also drilled and fitted the flap actuator bearing blocks with a #10 drill and a drill press. The rest of the day was spent priming all available parts for the fusealge that needed it.
