Riveted rudder skin to skeleton. Rolled and closed the rudder nose leading edge. I used a length of black pipe taped to the skin and rolled it with a big pipe wrench. The skin has a lot of spring. I thought I would crease the skin but with a lot of downward pressure while I rolled it, it came out OK. The nose skins were close with pop rivets per the VANS assembly manual.
