I had to order the wood prop forward bulkhead to fit the spinner. The Sensenech bulkhead was too big.The bulkhead had to be cut to clear the prop blades. Then the spinner is fit. Once measured to make sure it's even, I'll drill the bulkhead to the spinner and then fit and drill the backplate once I've fitted the prop to the engine and torqued it down.
