After a layoff of 7 months to move twice while my airplane was in storage I am back to work. I worked about 5 hours, very slowly because I was a bit rusty. Worked on fabricating F684 gussets and fitting them. Drilled and clecoed in bottom holes. Also fit F902's for both sides. Clecoed in F9101's which fit well right off the bat. Drilled holes from F9101 to F902. Also drilled F902 holes to skin. Began fabrication of F996B's but only got the rough shape cut out. Felt really good to be back to work.
