Brief Description: Drilled holes for steps, bent lower side skins
Drilled holes for steps in both side skins. Bent lower portions of side skins using technique recommended by the GBI video. Didn't do so well on the first one. Overbent in a couple spots making creases plus I tore the skin at the "apex of the cone". Did better on the second one but still not as nice as I would have liked. It will probably be okay once it's riveted but the creases will still likely show. More work for the paint shop! Clecoed on the side skins again. Called it a day.
