BRUCE'S WEB SITE
Date:  2-22-2009
Number of Hours:  3.75
Brief Description:  Finished mounting the aileron servo
Finished fitting the mounting for the aileron servo. Bolted the aileron servo in, still have to get two bolts for the last two holes, will need to order special bolts in order to have clearance on the servo body. Fabricated the control rod between the servo and the bellcrank. Modified the spacer sleeve on the bellcrank to allow mounting of rod. Bolted everything together.
Drilling the mount
Drilling the mount
Servo mounted
Servo mounted
Servo connected to bellcrank
