Finalized design of aileron servo mounting. Cut pieces of angle to length and began fitting them to the ribs and the angles spanning between them. Also will rivet in a plate on the angles that I'll use to bolt the servo to. Measured the plate to size, cut it out and then bent a 90 degree angle that will attach to the front of the servo. Riveted in nutplates to the plate and angle. Riveted the plate to the two long angles. Riveted the two long angles to the rib angle closest to the aileron bellcrank bay.
