Welcome to our RV-8 build log
Date:  10-11-2009
Number of Hours:  4.00
Manual Reference:  8-74
Brief Description:  Made the tank attach brackets
Marked out and cut the left and right tank attach brackets from the aluminum channel provided.
Used a hole saw to drill the optional 1" hole in the left bracket for the fuel line running to the flop tube.
Made the bend adjustments so the brackets fit flush with the fuselage as per instructions.
The instruction say to clamp the brackets to the T-405 angles and then to match drill #12 the two holes in the fuselage into the attach brackets. Unfortunately the top hole isn't accessible even with an angle drill so we'll have to find an alternative way to do this.
RH & LH F-863-1 Tank Attach Brackets
