Welcome to our RV-8 build log
Date:  12-11-2008
Number of Hours:  8.00
Manual Reference:  8-29
Brief Description:  Disassembled fuselage & made fuel valve bracket
Disassembled the tailcone and mid fuselage and machine countersunk for dimples the #30 holes in the F-822-1 forward floor panel.
Removed the forward side skins and re-cleco'd all sub-structure parts back to their respective locations.
We couldn't use the stock F-883-1 mounting bracket as we decided to upgrade to the Andair fuel selector. Fortunately we had a scrap HS spar that could be modified to do the job.
Drilled the fuel valve bracket to auxiliary longeron holes and disassembled the Fwd fuselage sub structure.
Tailcone and mid side skins removed
Machine countersinking Fwd floor panel
Andair fuel valve bracket made from scrap HS spar
