Removed the vinyl from the center bottom skins and deburred the holes and edges.
Rolled an edge break on the F-826-1 right center bottom skin to help it lay flat on the left center bottom skin. Also added an edge break on the aft outboard edges on both skins where they will contact the conical portion of the side skins.
Dimpled all the holes in the skins which are common with the seat ribs.
