Brief Description: Installed aileron brackets & gap fairings
Riveted the aileron hinge brackets and gap fairing to the LH & RH wing.
Installed the bottom skins with Clecoes and match drilled the flap braces to the bottom skins as well as the access covers.
Removed the flap braces and machine countersunk them to accept the dimples in the bottom skins. This is done so that the flap hinge can lie flat on the inside of the flap brace.
Outboard aileron hinge bracket
Aileron gap fairing installed
Preparing to match drill the flap brace and bottom skin
