Brief Description: Match drilled the LH & RH flaps
Match drilled the top skin to the skeleton and the hinge to the bottom flange of the spar.
We marked the rivet centerline on the flap hinge almost at minimum edge distance, so hopefully there will be enough edge distance on the wing side of the hinge once we align the trailing edge of the flap and aileron.
