Brief Description: Tank capacitive fuel sender plates and trap door
Match drilled the capacitive fuel sender plates to the tank ribs and trimmed the outboard plates to clear the tank stiffeners. Match drilled dimpled and riveted the plate nuts.
Made the trap door for the inboard rib of the left fuel tank. We are only installing a flop tube in the LH tank so on the RH tank this hole will be left open.
