Brief Description: Match drilled the wing main rib/spar assembly
Assembled the wing skeletons and match drilled the ribs to the main and rear spars. Removed the ribs and deburred the rivet holes. Drilled the 3/4" holes in the main ribs for the wiring conduit as per instructions found on Van's website.
