Bent the trailing edge of the trim tab skin and the inboard and outboard tabs. Match drilled the holes and machine countersunk the top of the spar to accept the dimples in the skin. Fitted the trim tab to the elevator and aligned the trailing and inboard edges and then match drilled the forward portion of the hinge. Completed riveting the trim tab.
