Welcome to our RV-8 build log
RV-8
Removed wings from the fuselage
Checked the LH tank and it is now also officially leak free.
Drained the fuel into my car and removed the wings from the fuselage.
Removed the flap actuator and control column and drilled holes in the mid side skins for the wing conduit.
Deburred all the rivet and screw holes associated with the wing root and flap fairings.
Rolled the edges of the fuselage bottom skins and dimpled the holes for #8 screws.
Draining the LH tank
Holes drilled for wing conduit
Rolled and dimpled bottom skins
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
