Welcome to our RV-8 build log
RV-8
Prepared for wing fuselage assembly
Removed the temporary aluminum spacer blocks from the center section assembly.
Installed the tank fuel lines and vent line fittings in the fuselage.
Modified four 7/16 hardware store bolts which will be used to temporarily attach the wings for rigging.
Marked out the wing lower inboard skins for drilling the center bottom skins as per instructions.
We decided to first mount the wings and then determine where to drill the hole in the fuselage side skin for the pitot line.
Spacer blocks removed
7/16 hardware store bolts modified
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
