Welcome to our RV-8 build log
RV-8
Riveted cooling ramp assembly
Cleco'd the cooling air ramp to the fuselage and final drilled the aft holes for blind rivets.
Removed it and deburred the holes.
Applied fuel tank sealant to the forward L.G cross member and forward floor panel where they contact the ramp and Cleco'd it in place.
Riveted the ramp to the fuselage as per instructions.
Applied a bead of fuel tank sealant along the full length of the cooling air ramp on both sides where it contacts the forward bottom skins.
Turned the fuselage upright.
Cooling air ramp riveted
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
