Brief Description: Installed seat belt brackets & bulkhead rivets
Bolted the LH & RH seat belt brackets to the lower longerons. Fortunately we had used a 1/8 spacer between the longerons and F-857C-1 angles when setting the skin rivets so it was easy to slide the seat belt brackets in position.
Riveted the aft end of the rear arm rests to the F-807 bulkhead.
Riveted the F-806A-L-1 & R1 bulkheads to the F-806F-L-1 & R-1 gussets.
Riveted the floor support angles to the F-805G-1 gussets and inboard seat rib angles.
Riveted the outboard tab of the fwd arm rests to the center section bulkheads.
