Welcome to our RV-8 build log
Date:  1-11-2009
Number of Hours:  3.00
Manual Reference:  8-63
Brief Description:  Fuel pump / filter brackets and pipes
We decided to complete the cockpit fuel and brake lines before attaching the forward side skins because of the improved access.
Match drilled, primed and riveted the fuel filter and fuel pump cradles to the fwd floor panel.
Cut the cradle pads and temporarily mounted the filter and fuel pump in position.
Made the filter to pump pipe (2 bends) and the return line from the pump to the Andair selector valve (1 bend). We used a piece of wire to model the required shape of the pipes and then copied them with aluminum tubing.
Airflow performance fuel pump
Airflow performance filter and Andair valve
Fuel pipes through gear tower
