Welcome to our RV-8 build log
RV-8
Match drilled the lower longerons
Match drilled the LH and RH lower longerons to the Fwd Fuselage Substructure.
Machine countersunk the bottom of the forward floor for the screws attaching the L.G box weldments. (2 per side)
Removed the lower longerons and deburred all the holes.
Added a radius to the aft end of the vertex on each longeron as per Detail C, DWG 67.
Clecoed and temporarily bolted the lower longerons to the Fwd Fuselage Substructure.
Inserted the auxiliary longerons and clecoed the landing gear box and spacer plates in position.
Match drilled and deburred the holes between the mid cabin braces and center section assembly.
Drilling the LH lower longeron
And the RH lower longeron
RH auxiliary longeron in position
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
