Brief Description: Match drilled seat rib assembly
Decided to continue with the seat rib assembly so that I have more parts to prime. It is just so much more efficient to prime in bigger batches.
Clecoed the seat rib assembly together and match drilled as per instructions.
Couldn't find the AB4-250 bar stock to fabricate the F-806E spacers and one F-814HPPX fwd seat belt anchor (The packing list shows two but three are required). I e-mailed Vans and they are shipping the missing parts.
I also match drilled the manual aileron trim brackets to the forward seat ribs after studying DWG OP-6 and the instructions included in the kit.
