Welcome to our RV-8 build log
Date:  8-17-2008
Number of Hours:  6.00
Manual Reference:  8-5
Brief Description:  Riveted gear towers
Riveted the RH and LH gear towers.
I double checked to make sure the forward corner angles have 5 mounting holes in the base flange and the rear have six before riveting them to the bulkheads. I also marked the hole not to rivet on the RH and LH aft bulkhead that is used to attach the mid cabin brace.
Temporarily attached the weldments.
RH forward bulkhead
RH forward bulkhead
Riveting RH gear tower
Towers riveted and weldments Cleco'd on
