Welcome to our RV-8 build log
RV-8
Attached LH Flap
Drilled the flap hinge using the same procedure as on the RH flap.
Modified the hinges on the RH and LH flap so that the hinge pins can be inserted from the center and secured on the flap brace.
Riveted the flap hinges to the wing.
Flap hinge pins secured
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
