Brief Description: Riveted flap braces & made short aileron pushrods
Riveted the flap braces to the rear spars and then placed some RTV between the wiring conduit and ribs to prevent chafing.
Cut the steel aileron pushrods to length and drilled the rivet holes. Primed the inside of both tubes by pouring primer inside and slowly swirling it around.
