Welcome to our RV-8 build log
RV-8
Installed inboard sender plates in both tanks
Routed the sender wires through the snap bushings and then crimped and soldered the terminals to them.
Connected the terminals to the inboard sender plates and covered them with tank sealant.
Installed the sender plates on the ribs and rotated the wires around the vent tubes.
Put some sealant on the wires around the vent tube to keep them in position.
Terminals crimped and soldered
Sealant holding wire in position
Inboard plate installed
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
