Welcome to our RV-8 build log
Date:  7-29-2007
Number of Hours:  4.00
Manual Reference:  6-12
Brief Description:  Completed the empennage
Assembled the RH elevator to the horizontal stabilizer. Trimmed the forward outboard edge of the horizontal stabilizer to provide sufficient clearance for the elevator counterweight skin.
Installed the rod end bearings on the rudder and mounted it to the vertical stabilizer.
All the fiberglass work on the aircraft will be done at a later stage so for now the empennage is done!
HS and elevator Assy.
VS and rudder Assy.
VS and rudder Assy.
