Brief Description: Continued R. Fuel Tank - Rib 7, Fuel Sender & PU
Riveted Rib 7 and covered heads with Proseal.
Installed Fuel Sender and Fuel Pickup on Cover.
Tested Sender - 030 to 248 ohms.
Torqued PU fittings to 110 in-lb. Didn't have to move the inside nut to make the anti-rotation Bracket fit correctly.
Covered a few more heads in the tank in Proseal.
Next: - Finish covering the rivet heads inside the tank. - Make sure the end ribs are fully sealed inside focusing on the tip. - Install Baffle - Install Z-Brackets - Install Cover with PU and Sending Unit
