Brief Description: Drilled Backing Plate, Z-Brackets for Right Wing
Drilled the W-423 Backing Plate to the LE. Came out nice.
Match drilled all the Z-Brackets to the Baffle. Marked the Spar holes on the other side to see where they will be drilled. Not bad.
Clecoed Fuel Tank to outeside ribs and Baffle to test fit on Spar. Tight seal to LE, but a little gold shining through between the Fuel Tank Skin and the Top Inboard Main Skin.
