Made Wing Stand with casters using an article on Vans Aircraft Builders site. Took a little time a few bucks at Home Depot, but it turned out well. It took quite a bit of work to open the Leading Edge cutouts enough with this thick pipe insulation. We'll see when I move the first wing into it....
I did touch the plane too. I roughed in the Pitot/AOA tubing. And I ran the Stall Warner wire through one of the holes with one of the tubes. Looks like I need to make a bracket to keep the tubing from rubbing on the Bellcrank.
Looked more at wingtip lights. I think the skins will go on AFTER all this is figured out and the wiring is done...
