Took a long time to figure out how to line up the electric Elevator Trim. The drawing has a dimension reversed for edge distance (should be the right bracket, not the left). Finally got the cover plate drilled for the brackets. It's not perfect, but pretty close. Just need to deburr and prime before riveting it all together. If every small thing takes this long, it'll be YEARS before I finish, but it was my first time working on the plane in 7 months!
Also, just clecoed the whole Left Elevator together to figure out how it goes together. I had originally installed the tip rib backwards. Need to get my brain back into buiilding! lol
