Riveted Ribs 1, 5, & 6. Sealed and clecoed both reinforcement plates onto Rib 1. Riveted the tooling hole on Rib 7. Took 2 tries. Used a WAYYY too long rivet on the first try. Riveted the reinforcement plate onto Rib 7.
Began fitting the Vent Line and Fuel Pickup. Installed the bushings for the Vent Line.
Next: - Finish Vent Line and Fuel Pickup - Drill hole for Vent Line in Rib 1. (WHAT SIZE?) - Rivet Plates on Rib 1. - Seal and Rivet Rib 7. - Install Baffle - Install Fuel Pickup Cover & Sender -
