Russ Karnap
RV-7A
Right Aileron - Finish
Finished the Right Flap.
- Riveted the Spar and Hinge
Used the my homemade angled pull rivet tool. Worked well. Left a little smile on the rivet heads, but not bad. MUCH better than not using it.
Checked twist. The Left Flap was almost perfectly flat. The Right Flap had a little less than 1/8" twist/rocker.
Right Flap
Right Flap - 1/8* twist
Right Flap Top Skin
RV-7A Home
776
EAA Tech Counselor R
Emp: Elevators
Emp: Horizontal Stab
Emp: Rudder
Emp: Vertical Stabil
Empennage: General
Primer
Primer/Paint Prep
468
