Deburred all Left Fuel Tank parts. Dimpled all Left Fuel Tank Ribs.
Made Anti-Hang-Up Guides for Left Fuel Tank. Installed the one on the 1st Rib. Installed one side on the other one. Need to have the Skin on to finish the second hole.
Cut the Access Holes in both Root Ribs. The flycutter worked great. Carefule, the pieces are jagged and RAZOR sharp afterwards.
Smoothed out the spacers for both Fuel Elbows (Vent and Intake).
Match drilled the T-410 outboard Nose Reinforcement Plate.
Made scalloped indents in T-405 Tank Attach angle for the rivets that join the Fuel Tank skin and the Root Rib.
Cut Access Holes in Both Root Ribs
Fuel Tank Anti-Hang Up Guide
Fuel Tank Anti-Hang Up Guide and Reinforcement Ring
