Brief Description: Made T-405, L.Fuel Tank Stiffeners, Z-Bracket Nutp
Fabricated both T-405 Brackets. These are the L brackets on the outside of the inboard Fuel Tank Ribs. See pic below. Came out nice, but still have to think about rivet shop head clearance where the Skin rivets to the Rib.
Match Drilled all the Left Tank Stiffeners. Need to deburr the holes on them and the skin.
Installed all the nutplates on the Left Wing Fuel Tank Z Brackets and the three on the Main Spar for the Inboard most Z Bracket. Deburred all the holes for riveting to the Left Tank Baffle.
Drilled out bad rivet from inboard most Main Rib and replaced without issue.
Plasti-Dipped one set of Cleco Pliers. Will do the other set tomorrow.
